Draining battery
This could be caused by anything from the boot(trunk) light staying on to a faulty alternator.
If you have a 12v test light, it is a simple process of elimination.
Disconnect the battery earth when the battery is charged and then connect the test light between the negative terminal and the disconnected lead(the positive side of the battery must remain connected). If there is nothing draining the battery, the test light will not be lit. If it is lit, the brighter the light the bigger the drain.
If there is a drain, remove and replace each fuse in the fuse box one at a time until the light goes out.
Then see what works off that fuse and you've found the problem.
If the light is still on after you've tried all the fuses, then it is either a non original peice of electrical equipment causing the drain or the alternator or starter motor.
