450slc5.0cab 280sl5sp 280se4.5 500se+500slAMG +250seStkW108 350sl4spdX3 500secEuro
Disconnected the damper from the pump.
Cracked supply line loose from filter, but nut is rusted, so the whole pump assembly or filter was going to need to spin to disconnect without cutting the supply hose on the car. I don’t want to do that. So...
Whole pump assembly removed (as planned really).
The hose from the tank didn’t let much out at all, total varnish, but red brown oil-looking, not black tar.
I got the 19mm hose loose with a nice big 3/4” wrench and some leverage on the bumper. Never again will I try to do that with the pump assembly in place. Got the hose out.
Not as if it would have worked anyway, but the strainer wasn’t centered over the hole. So no chance of pulling the strainer in place.
I put 2-3 quarts of used machine shop cutting oil in the tank and realized it wasn’t coming out the bottom. I considered letting it sit, but decided to move forward removing the tank.
Bulkhead and tank fasteners removed. Had to grind off left three floor bolts because they disintegrated when I put a socket on them. removed the filler rubber donut.
Removed the return line underneath on the driver side. I expected big flow of cutting oil I just poured in but got mostly nothing.
Started pulling the tank out above and disconnected the vent lines on the left. This was perhaps one of the hardest things, at least what caught me by surprise the most. I had to remove the clamps and then twist the hose with channel locks to get it started and finally got those hoses off. Moved to the driver side and repeat.
Removed the sender plug. The top of the tank was covered in water. Maybe it was from my major washdown when I was hosing out the entire car, and it hasn’t been hot or dry enough to evaporate. I imagine that if the top was leaking water here it would be a bigger mess there.
Finally started lifting the tank up. Holy cow. That’s more than dry varnish and 2-3 quarts of cutting oil.
I drained about 3 gallons out of the tank and am now waiting for it to dry the varnish to dust as it seems to always do when you let the tank dry out.
The strainer looked far better than I expected on the top half, almost as if it would have been fine if I just filled the tank. I will clean the strainer and install it after everything starts turning to dust.
Lots of varnish chunks in the tank to dry out. It will be several days. Unless I come across a tank that I can use, this project may be on hold for a little while.
