1978 450 sl
there's an upper, and lower wire terminal on the starter solenoid. Which color wire goes to the upper and lower? (while starter out, I forgot!):confused:
1976 450SL, 1945 Willy's CJ2A, 2007 Dodge Nitro
Not sure if you've got this one figured out yet, I didn't see any comments. When I pulled mine last week. For mine there are 2 smaller wires, one has a smaller connector than the other. The smaller one will not fit the other screw. As for the larger wires there are 3. Two of them connect to the larger bolt and the wire attached to the side of the starter attaches to the smaller bolt (also has a slimmer nut).
Hope this helps. I had to memorize mine because the wires were so dirty I couldn't get the colors right.
