1983 MB 380 SEL Anthracite Grey , 1981 MB 380 SL Lapis Bleu
Hi friends. I just purchased a 1978 450 SLC and a 1973 450 SL. The SL I got for a parts car and the SLC were included in the deal as both had mechanic's lien. The SLC, as can be seen in the pictures has sat for quite a long time and while there are a few missing parts on the engine, the car is pretty much complete. It would make a very good parts car.
There is rust-through on the fenders and in many places on the body. The seats have wear but the door cards are in excellent shape. The 14" bundt wheels are there. I have the valet key but I do not have the trunk key and am not sure what is inside. I do not want to break the lock at this point but hopefully, will find a way to pop the trunk without damaging the lock. I will reach out to MB to open with a master key.
Underneath, the exhaust is loose but complete with the catalytic converters. The fuel distributor is missing as is the Becker which a Sony system is in its place. From what information I could get on the car's history for being at this shop was for rocker arm issues (probably more). I have a complete set of 16 brand-new rocker arms part # 1160551501 Febi Bilstein still in the box with numerous other parts that will fit this SLC and other V-8 R107s.
I would like to offer this SLC as a complete car but depending on the interest, I may eventually remove some parts for you. The car has a wealth of good parts. If you are interested in the entire car, you will need to tow it from North Carolina. For the whole car, I am asking $1200. Thanks much!
UPDATE #1 10/16/22:
I have started shooting pictures underneath the SLC and so far, it is quite solid. The spare tire well is very solid. The drainage openings are intact and the exhaust is complete but loose. Interestingly, the first aid kit is complete down to the brochures, scissors, and more. Please view the additional pictures.
UPDATE #2 10/17/22
Today, I went over the packet of service records on this SLC and for almost all of its life, all of the major systems had been regularly maintained. A lot of new OEM parts replaced the old parts. The exhaust, fuel pump, accumulator, filter, brakes including the master cylinder, thermostat, and much more were replaced. The shop that performed the majority of the work was and is still a highly reputable establishment.
What went wrong? From what I am finding; the valves had a not-so-cordial meeting with a piston(s) as the timing chain guides are broken, and the timing chain has jumped. This may explain why the rocker arms, cams, (and a lot more) needed to be replaced.
Sadly, it may have been too much for the owner to repair and subsequently, the car was abandoned. Being that an SLC was never in abundance as an SL, this car could possibly be restored but, there are some challenges.
The carpeting front and rear are in excellent shape and clean.
The suspension is tight and the car does not sag.
The left fender has rusted through at the brow.
The door sills are rusty and the cancer would need to be addressed from the roof down however, parts are still available.
The fuel distributor and other engine parts are gone.
The AC compressor is still there.
The engine would either need to be totally rebuilt or replaced but the end result of rebuilding may be the route to go because of what it is.
Since the car was kept on a concrete pad, there was also an active feral cat population in the area so there is no rodent damage.
I am unable to give this SLC what it needs as I have two SLs and my immaculate one-owner 380 SEL. I simply do not have the room but it is kept covered from the elements at my home. I hope somebody out there would use it for the wealth of parts or perhaps a candidate for restoration.
I will update again and post more pictures once I get the trunk opened and get completely under the car.
Automotive tire Motor vehicle Hood Wheel Tire
Automotive parking light Land vehicle Vehicle Car Automotive side marker light
Car Steering part Motor vehicle Automotive design Gear shift
Speedometer Gauge Motor vehicle Car Vehicle
Automotive parking light Grille Hood Automotive lighting Vehicle
Wheel Car Tire Vehicle Automotive parking light
Car Land vehicle Vehicle Hood Automotive lighting
Grille Hood Automotive lighting Motor vehicle Automotive design
Wheel Tire Car Automotive parking light Vehicle
Automotive parking light Grille Automotive lighting Automotive tire Hood
Here is the information on the car:
CHASSIS NUMBER
Model code: 107024
Commercial model: 450 SLC
Steering and Transmission: Left Hand Drive, Automatic Transmission
Serial number:
PAINT CODES
Paint Code: 735 - astral silver (astralsilber)* (bundt style wheels)
INTERIOR CODES
OPTION CODES
Option Code: 518 - BECKER RADIO AVUS CASSETTE, FULL STEREO, KURIER, AM/FM (Valid from 1986-08-01 00:00:00 to 1990-11-30 00:00:00)
Option Code: 518 - BECKER RADIO AVUS CASSETTE STEREO KURIER MW/USW (Valid from 1982-11-01 00:00:00 to 1986-07-31 00:00:00)
Option Code: 518 - BECKER RADIO EUROPA, STEREO (Valid from 1970-04-01 00:00:00 to 1973-09-30 00:00:00)
Option Code: 518 - BECKER RADIO MEXICO CASSETTE FULL STEREO (AM/FM - U.S.A.) (Valid from 1974-02-01 00:00:00 to 1980-10-31 00:00:00)
Option Code: 518 - BECKER RADIO MEXICO LM/MW/SW/USW - USA (Valid from 1963-01-01 00:00:00 to 1970-01-31 00:00:00)
Option Code: 518 - RADIO MB EXQUISIT WITHOUT TRAFFIC NEWS DECODER, WITHOUT RDS (Valid from 1992-07-01 00:00:00 to )
Option Code: 531 - AUTOMATIC ANTENNA (Valid from 1963-01-01 00:00:00 to )
Option Code: 588 - THERMOKING AIR CONDITIONER AND ELECTRIC WINDOW LIFTERS (FRONT DOORS) (Valid from 1970-04-01 00:00:00 to 1972-12-31 00:00:00)
Option Code: 588 - AUTOMATIC CLIMATE CONTROL AND ELECTRIC WINDOW LIFTERS (FRONT AND REAR DOORS) (Valid from 1977-01-01 00:00:00 to )
Option Code: 592 - WYELLOW FOGLAMPS (Valid from 1963-01-01 00:00:00 to 1965-10-31 00:00:00)
Option Code: 592 - HEAT-INSULATING GLASS, ALL-AROUND, HEATED REAR WINDOW PANE (LAMINATED GLASS), BAND FILTER (Valid from to )
Option Code: 592 - HEAT-INSULATING GLASS, SIDE WINDOW PANES (Valid from 1967-02-01 00:00:00 to 1971-01-31 00:00:00)
Option Code: 592 - GREEN HEAT-INSULATING GLASS ALL ROUND, HEATED REAR WINDOW, LAMINATED SAFETY GLASS - TINTED STRIP (Valid from 1972-01-01 00:00:00 to )
Option Code: 639 - RADIAL-PLY TIRES, ELIMINATION OF WARNING TRIANGLE (Valid from 1973-11-01 00:00:00 to 1974-10-31 00:00:00)
Option Code: 639 - ELIMINATION OF FIRST-AID BOX AND WARNING TRIANGLE (Valid from 1977-08-01 00:00:00 to )
Option Code: 410 - ELECTRIC SLIDING ROOF (Valid from 1965-03-01 00:00:00 to 1988-02-29 00:00:00)
Option Code: 467 - CENTRAL LOCKING SYSTEM AND INSTRUMENTS WITH ENGLISH LETTERING (Valid from 1970-04-01 00:00:00 to 1993-10-31 00:00:00)
Option Code: 467 - 461 + 462 + 463 (Valid from 1968-07-01 00:00:00 to 1969-08-31 00:00:00)
Option Code: 491 - U.S. VERSION (Valid from 1963-01-01 00:00:00 to )
Discussion Starter · #2 ·
Hi Please let me know if I posted in error. I always strive to abide by the rules. This SLC is a car that I do not intend to keep as I got it in a package deal. I was hoping that if there is an interest in this car and from the parts off my 74 450SL, I would be happy to share with others. Let me know what I need to do to make sure I am not in error posting. Thanks!
