This car sits over winters but was running last Fall. When I try starting it now, it will fire just a couple of revolutions...not making it to "idle". Then it appears flooded and won't fire again (plugs dripping). It will behave the same way after it sits for an hour or so. OR...if I pull the fuel pump relay. W/O the relay it will go ahead and burn off the residual fuel and idle for 10 seconds or so.
After the burn off, it will start again for a couple revs with the relay back in...then flood.
Could there be a lack of fuel supply CONTROL on startup? Not sure what device is suppose to reduce fuel to injectors.
Or...might the diaphragm in the fuel distributor be bad? I have decent return pressure on the airflow plate, so I believe piston is operating.
I just took ownership of the car, but know it was running last fall. Previous owner may have adjusted fuel supply valve...? Is there a factory setting there?
Any input would be appreciated before I send FD and WUR in for rebuild.
