1 - 20 of 30 Posts
I'm at my wit's end. I'm restoring a 74 450sl and I can't fix a fuel problem. I'll explain the problem, then tell you what I've done.
Engine starts right up and idles initially. I've got a fuel pressure gauge on the fuel line. It takes about 5 seconds to start to build pressure, and over about 10 seconds it builds to 30 PSI. The engine starts immediately and idles. The RPM drop in direct correlation to the pressure building. At 30 PSI, it chokes itself out. My assumption is that the system is getting so rich, it can't run. Lots of smoke as it chokes out.
Too much fuel is either TPS, MAP, injectors, or ECU. I've removed the 9th injector (startup injector). Half injectors are new. All the injectors have been leak tested (using water so that I didn't kill myself). They didn't leak water and the cone was acceptable considering that water is a lot heavier than gas.
TPS: The TPS has three modes: IDLE, 'in-between', and FULL. It is clean and adjusted. At idle (no pressure on the gas pedal), the output pin is GND - movement of the pedal causes it to OPEN. The 'in-between' mode alternates between GND and OPEN ten times as the pedal it pushed. The FULL output is OPEN all the time. It should go to GND at full gas pedal travel, but it doesn't. That shouldn't be my problem (so says the guy who can't figure out the problem). The most logical thing that WOULD cause the problem is that if the TPS GNDed the FULL pin. That would override the MAP sensor and have the ECU dump wide-open fuel all the time. The FULL pin is OPEN, not GNDed.
MAP: I can put a vacuum on it and hold a vacuum (implies diaphragm is OK). Open circuit resistance is correct for both coils. Using an impedance meter, I measure the inductance of the coils and they vary linearly as I increase/decrease vacuum. I don't remember the reading (typing from memory here), but it was something line 0.7H - 0.9H on the small coil and something like 1.2H to 1.5H on the larger coil.
ECU: wiring to the ECU appears to be good. I've opened the ECU and everything looks OK, no obvious corrosion, smoked parts, or leaking caps (I'm an electrical engineer - without having schematics to check it with, it appears to be just fine).
Fuel pump is new, fuel lines are new, fuel filter is new.
What is causing this system to dump so much fuel???? I'm about ready to rip out this motor and put in a modern engine. I'm getting desperate. What am I missing?
Have you checked timing as well as looked to see that both cams are aligned at TDC to check for stretch of the timing chain?
Have you done a pressure test on each cylinder?
If you feel like it is fuel pressure related, which im not convinced it totally is (but by no means am I an expert), have you tried turning down the fuel pressure regulator?
Just a few thoughts, I restored a 75 and had a ton of trouble figuring out why it wouldn't run and it had similar symptoms, turned out the timing chain was stretched.
First and foremost: Clearly something I believe to be OK is not. So I'm no longer positive about anything. Here is what I believe to be the answer to your questions.
I did do a pressure test on all the cylinders and (again from memory) were all about 120 PSI.
Forget turning the fuel pressure regulator down, I can disconnect the fuel pump and the car will idle beautifully at 0 PSI. But just turning down the fuel pressure is a "cheat" that will only mask a bigger problem, right?
I checked the timing chain for stretch and replaced the timing chain guides. The timing is good (my neighbor is a Lexus mechanic and I got him to look over my shoulder to verify I had it right).
The trigger points inside the ignition distributor tell the ecu when shoot fuel I believe.
The throttle position sensor sends a throttle position.
The manifold pressure sensor senses the level of vacuum, and I believe is only in play when not at idle.
There’s a knob on the ecu for idle mixture. Righty richy, lefty leany I believe.
There are coolant and air temperature temperature sensors too.
The Aux Air valve should cutoff additional startup air as the engine warms up, as the coolant expands the wax in the bulb.
Are you sure it’s running rich?
Are you using the correct pump?
1. Yes, but the ECU looks at 3 things on the TPS. IDLE, FULL THROTTLE, and accel/decel. A FULL THROTTLE TPS signal should "over-ride" the MAP sensor and cause the ECU to send max fuel.
2. MAP is in play when not IDLE or FULL
3. Yes, I've gone full rich to full lean and there is no change.
4. Coolant sensor is in place; air sensor is connected and just lying in the engine bay while I have the air housing off
5. The aux air valve was broken - seized in place and I removed it. It really is only needed when the car is cold and that's not a problem for me. I put an aftermarket water temperature switch to control an aftermarket electric fan on the radiator
6. I say it is rich because it shuts down as the FP rises, smells of gas, runs rough/misfires, smokes, and eventually I'll get enough gas in the oil to require a change.
7. Fuel pump is an aftermarket airtex pump, but the problem existed with a the OEM pump.
I would try decreasing the fuel pressure regulator and ensure that the pump you have on it is correct. How long does it run, does it drive? If so for how long? When you say misfire does that mean backfire? Does it start when it is cold and hot? It really sounds like timing if you are getting misfires and gas in the oil
Misfire does not mean backfire, just the occasional 'bump and miss'. It starts just fine when cold or warm. See the video I posted.
The timing is dead-on the marks at 5deg BTDC.
Again, note that I'm responding with a bit of humility: Something I "know" is clearly not true or else I'd have figured this out by now.
Video link does not work.
I would recheck your cam alignment if it is misfiring but the ignition is timed correctly. Even being off a little caused me weeks of headache.
Can you post some pictures of your engine intake area - curious about that work you did on the idle circuit by removing the AAV and what lies in its place. I am assuming you have blue Bosch Injectors. I am also curious about the placement of your fuel pressure gauge and resulting fuel circuit.
Don't give up - I think we can figure it out. I have gobs of spares to help you diagnose when we narrow it down.
Have you had a look at your pulse generator (trigger points) in the base of your distributor?
Discussion Starter #13
I'll post pictures of what I've done tonight.
The fuel injectors are what Rockauto.com sells Standard Motor Products FJ118, the other 4 are OEM that I rebuilt. (<- yes, that statement should make you suspicious).
I haven't put an oscilloscope on the trigger points, but I did put little fuel injector noid lights at the end of the cables and saw clear firing pulses. the Trigger Point contacts are clean.
As far as the fuel pressure gauge, it is plugged into the fuel line where the cold start injector used to be. I removed that injector because a) I wasn't having trouble starting the car cold, and b) as I was getting too much fuel I wanted to remove it as a possible source of the fuel.
If we are assuming that timing chain isnt stretched and fuel injectors arent sticking open (doubtful), it really seems like the pressure is too high. What kind of fuel pump is on it and have you tried reducing the pressure from the regulator?
I had this problem on my Djet powered W114 280E. It was due to a failed engine temperature sensor. Open circuit equals infinite resistance equals infinite injector opening time. Check it with a multimeter when cold and warm. I can't remember exactly but I think cold it should be about 2kohm, at engine temperature it is about 600ohms, but check the manual. Make sure you check it when hot as mine didn't go open circuit until it warmed up.
Discussion Starter #18
This is the one on the back of the passenger side cylinder head?
Just a side note. Trigger Points work (fire)(create a pulse) when they are closed not open. 110 - 115 deg. should be your target.
1 - 20 of 30 Posts
About this Discussion
7 Participants
cushjbc
Mercedes-Benz Forum
Full Forum Listing
