My new purchase is in worse shape than I thought.
Full tank leaks fuel(anyone drop their tank?)
All tie rod ends are bad
Idler arm bushings
Window washer not working(bellows pumping, nozzles clean, check valve moving??)
Horns not working (both have one wire off, no power, fuses are good)
Blinker switch broken ( arm won't stay up for right turn, big problem for son with one arm)
Glow plugs only get power while cranking
Vibration while under load
I need a service manual and plenty of parts. Any ideas or suggestions are very much appreciated:
Idler arm bushings
