1973 450SL, (Previous 2008 ML350,2002 E320 Wagon, 2000 SLK230)
The other day the front right fender trim fell off! The front-most post seemed to break off (rust). I received the new trim piece, and I'm current waiting for the new retainers. I have a couple questions before I start this project.
The new piece - I see the L Bracket, the middle post - push in, then the front post that appears to be a threaded post. Does a nut go on the other side of this post or is it simply for additional gripping when inserted in the retainer?
The old piece that is in the retainer that broke off. What is the best method for extracting without damaging the paint?
I'm including pictures of the old and new trim piece.
1986 560 SL
Too late now, but you could have reattached the old trim using 2-sided tape instead of the clips. Don't throw it away.
My memory is fuzzy, but I think that threaded post is secured by a nut. Try punching out the stub from the outside.
