New gas tank, filter and fuel pump. I cleaned and tested the fuel injectors, cleaned out the fuel rails. .. I had to install a Holly fuel pressure regulator with a return line, , because no one has the original stock regulators. There is a pressure gage on the regulator and the only way that i can get the engine to run is to set the fuel pressure to 75 psi, it dies out below 60psi, i believe that 28-30 psi is what the pros recommend , also it does not run properly at that high pressure. I would sincerely appreciate any suggestions and feedback, Thanks Al
1987 300SL
And by running after 25 years, does that mean it sat somewhere and wasn't used for 25 years and you're getting it going again?
83 280 SL- 5 speed-The PIG
If you haven't done it already....please complete your profile with year and model.
Trust me....this will help you in the long run.
---->click on your icon (top right hand corner of your screen)
----> click on Account Settings
---->go to Account Details
----> add vehicle details
---->ADD your make model YEAR
----> click save.
You have to install a fuel pressure regulator on the fuel return line that will maintain a pressure of about 30psig in the rails. The pump should be a djet pump that will flow 1 l/30sec against that 30 psig pressure. Wasting your time until you have that.
Reactions: nobby
