1983 300cd
Well,
It's running great and a ton of fun to drive. New problem however,
When you turn the steering wheel it makes an awful creaking noise.
I have replaced the subframe mounts and the tortion bar bushings.
I have greased the joints and I still have the problem.
Has anyone had this problem and would you please share any possible solutions.
It can only be a seized tie rod or drag link end ,a seized idler bush on the passenger side or ...'The dreaded Steering box fitting in the chassis cracks'.
Look at the three bolts that hold the box to the chassis rail,clean it with a wire brush and examine very closely for cracks around the three bolt heads.
It's easily fixed with steel plate to reinforce the chassis but it's a common problem.
1972 280E/8
Broken engine Mounts-they may look ok but engine can "lean" and hit chassis rail or steering box.
Cracked chassis in vicinity of steering box/engine mounts.
As merc.mad6.3 said common fault but easily fixed.
1983 300cd
Discussion Starter · #7 ·
Thanks everyone for your advise. Replaced upper & Lover control arm bushings, idler arm bushing and engine mounts. Not only has the noise dissapeared but I think that I have the nicest riding 250c on the planet. Thanks again!!
