I am changing the engines out between a 280S and a 280SE, both are 1969 4 door models.
I am looking for a source for the wiring schematics where I can see the differences between the models.
Would appreciate any help!
Only difference is in the fuel system wiring. Carb engines have a connection for the stop solenoids and autochoke and the MFI has a cold start solenoid and a cold start valve .
The cold start valve requires a relay but the wiring should come with the engine.
1998 SL500, 1959 220S, 1970 280SL
You also will need to wire in the relay for the fuel pump. and wiring from the relay to the pump.
