1961 MB Ponton 190b Reverse gear problem
1 reading
1.2K views 8 replies 3 participants last post by  nigel slade
HELP!!!!! Just bought a 1961 MB 190b 4 speed manual. Absolutely love it. Bought it yesterday in Melbourne, and drove it back to Tassie. Ran perfectly all the way. Used my reverse gear a few times in Melbourne traffic yesterday. Then upon getting home, stop the car, got back in and I cannot put it in reverser gear. All other gears work perfectly, but not reverse. Can someone please HELP me with this. What is likely to be the problem and how do I fix it?
Congrats, I have one, the first was in 1961 in East Africa.
I assume you are pulling the lever towards the steering wheel beyond the 1st-2nd gear positions and then up.
Check all the bushes including the ones under the steering wheel.
Have a look at mbzponton.org It's a US site wit plenty of information.
#4 ·
I kept my EA Ponton for 7 years and was registered in 3 different countries.
Did nothing to suspension apart broken shocks, cylinder head off burnt valves.
Gearbox out to fix selectors, could only get gears 1, 3 and reverse. sent box to MB to fix
Taking the box out was easy, no mountings and I was much younger then!!!!
#8 ·
I was many decades ago. It was fixed by MB in Nairobi Kenya. It was some thing to with selector forks, indent ball bearing had fallen out
If you don't have a parts book use niemoller mercedes on the net to get exploded diagram of the parts.
Also the box use ATF automatic transmission oil. If it has gear oil EP90? it will be almost impassable to change gear when cold.
