I checked the sticky for online mog maunals and found the avango link whick is awesome for info but i did not find anything for the older 411.
I'm trying to sort out the wiring in this old truck, the way it is wired right now,
-Ignition on seems to click on when you click/push down on key in 0 position red light, lights up.
-position 1 fog lights
-position 2 low beams
-position 3 hight beams
Not sure if it comes from factory like this, i'm sure it has been tinkered with in the past 50 odd years.
If someone can send me a good wiring diagram link or confirm it is supposed to work like this, that would be very helpful.
Also if someone can explain the start up procedure. like what position your supposed to have for glow plugs and actual cranking. I have that knob that you pull half up to activate glow plugs and then full out for starter, just wondering if my system is operating the way it should.
1959 411
Regards
1959 411
Regards
