An introduction:
This all started with the itch for an old Benz... I was torn between a W124 or W201, but the plan was for a mild turbo M103 build with some kind of period correct body and wheels. I stumbled on a mostly running, but otherwise decent 1993 190E for $1000 and well... I couldn't resist.
The car had a few known issues:
-No keys
-Failed ignition (more on that later)
-Failed brakes due to a bad rubber brake line
-Running extremely rough
The car did come with a new set of Depo headlights (I know... but hey, they were free) and a full set of YellowSpeed Racing Super Low Coilovers. Those coilovers wouldn't have been my choice, but we'll give them a try and see how things work
Overall plan for the build is to throw big brakes from a 400E on it, drop it on the coilovers with Fifteen52 Super Touring Tarmac EVOs, then push about 7-8 PSI through it with a low budget turbo setup. Once it's running well enough to justify the expense I'll source an EVO 2 body kit and tackle the fun of fitting that to the car.
Here is the car after it was towed to the house (a keen eye will notice the lack of steering wheel and the instrument cluster torn out)
As mentioned the car had a failed ignition switch and was missing all the keys. No big deal, but what I didn't know was that the previous owner had attempted to drill the ignition out only to succeed in snapping off a drill bit deep in the cylinder.
What followed was a multi week saga of waiting on an ebay sourced ignition assembly, judicious use of a dremel, grinder and drill, ultimately leaving me with a running car, albeit with no key for the doors or trunk.
Rough running was ultimately sorted by bleeding the fuel injector lines at the injectors, however the fantastic guide HERE was an invaluable resource and I highly recommend anyone with an M103 read and bookmark it.
Next up was cleaning the interior and getting the instrument cluster and steering column back together.
Hey free cassettes and free coilovers? Not too bad!
Once the interior was cleaned up I threw a vintage Nardi wheel in the car and things were looking pretty decent on the inside.
The Depo headlight install was extremely straightforward using the correct Euro 6-pin connector (part # 011-545-50-28) and wiring diagram below. The connectors are only about $2 each from any of the big parts suppliers, and I'd highly recommend anyone going to Euro style lights use them instead of jumper wire, etc... I elected not to use a jumper from the turn signal plug for the "city lights" feature.
At this point I had a decent running and looking 190E, but with no brakes. Next step was a full tune up, before pulling the car in the garage to tear in to the brakes and suspension...
-No keys
