1995 E320
My auxiliary fans are not working.I did search all forum but I did not find a similar case.The fans does not start at all. even when the temp approaches 120C. At the hwy speeds the ac work fine.But in slow trafic temp increses and the ac cuts off.Also when I put the key in whitout starting the engine the fan starts a little but they stop imediately.
I am suspecting the ceramic fuse or the relay or...I don't know.Please help.
'86 190E 2.3L
I had this problem too! There is a certian spot when you turn the key that a connection is made to the fans. When you start your car you just turn the key back VERY slowly until you hear a click and the fans will turn on. Dont worry it stays in that spot until you move it, just watch out about ajusting it while in traffic becuse you may turn off your car[:D]
btw what year is your car?
