No wiper system, but..
I did get the Euro headlight assemblies.
1 - You can use your current switches and wires if u like. The euro lights have 5 pins, the US ones have 4 pins, so you can just pull your current plug apart and connect wires 1 by 1. Or, you can look for an adapter that goes between the headlight and your current plug.
2 - european cars have 2 headlight switches. one is just like the US cars, and the other is a vacuum switch that adjusts the angle of the headlights (up/down). If you want this, you'll need a new trim piece, a new switch and vacuum lines (and vacuum know-how)
3 - You can reuse your H3 bulbs (foglights), but you will need to get new high/low beam bulbs - the euro's use H4 bulbs. They're easy to get.
Hope this helps.[
Hope this helps.[
