hey ya i had the same problem, i have a 90' 2.6 for as long as i can remember i had the problem that i would turn the key and i would get a struggle followed by a slight vibration. <br> <br> Heres the answer: COLD START VALVE<br> It shoots a stream of fuel into the main intake right after the air filter. It works much like a regular fule valve except its open for about ten seconds instead of milliseconds like your main valves.Just have it checked out and change it, make sure the timer switch is still good too that might be the problem as well.
