Hi, i have a big problem and would be grateful if anyone could help.
Basically i was driving my 2.3-16 just after i bought it and on 3 occassion when i went to change gear the clutch had not resistance. I pressed the pedal and the clutch just went to the floor and remained there until i pulled it up with my foot. But then after pumping the clutch i was able to get the car in gear.
On the 3rd occassion after getting the car in gear the clutch began slipping. I thought that the plate had got hot and hence might be causing the slipping, but it still does it even if the car is cold.
Also i thought the slave cylinder may of gone, but i am not sure.
Has anyone had any similar experiences?
Also i am gonna need a new clutch?
Thanks in advance.
Triple-R
