1987 190D 2.5-Turbo
Hi All,
I absolutely love my 190DT sans one thing, on wet roads (even without aggressive driving) my car has a tendency to lose traction and fishtail when shifting between 1st and 2nd gear and whenever going around any real corner. My question then is: are there any stock-looking wheels that are wider which can be mounted to an 87' 190DT?
Thanks in advance for the help!
Moderator
2.3-16 | A3 2.0T | 986 Boxster
Hi All,
The stock 16V wheels are wider, 15X7. The 8 holes from the W202 are 15X7 and can be found pretty cheap. Going up to 16 in the SL from the early 90s had the same looking 15 holes the 190 had, I think in 16X7.5 and 16X8.
There's many options.
1987 190D 2.5-Turbo
That actually sounds fantastic. :bowdown:
I've never messed with aftermarket or replacement wheels, would there be any fit problems (that you can think of) from mounting a 7.5" or 8" wheel on a bone-stock 190DT?
Tire quality and design is more imortant than wheel width for wet traction. Mine does it as well because the diesels can have a hard 1-2 shift and the 2.5DT make good torque at low rpms.
2000 :W220 - 1986 W201: 16v Nam,16v Euro- 2002:SL500 Silver Arrow.2002:Avalanche-
Your 2.5TD has very good power for this W201 body , wider tires is more like DTM looks and stability associates with a good tire thread design , stay with comfort and road huger from Michelin MXV4 you gonna luv theses..
Best part of MB is 5 lugs pattern are the same @ 112 x 7" up to 8"1/2 and ET30 and up to 45 will fit good on this W201 body.
IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
i have 16x8 on my 190 with nittos and they arent bad even in snow.
