1 - 8 of 8 Posts
Does anyone know where u can buy the lower rocker panels on a 190d? Im talking about the whole panel. My 190 is rusted out at the jackpoints, the jackpoints are fine but the sheet metal around them is junk. Worse case Im going to cut it out any elimate those jack points...basically cover them up, but if I can get that part I will save them.
Kevin
2006 E55: 1999 ML430; 2002 E430 4matic; 1988 190E 2.3; 1993 XL883
I've seen that area rust out. I haven't seen that panel for sale, but you could Bondo or possible fiberglass around the jack point to fill in the void. Then spray the whole bottom panel with a fresh coat of paint. I would leave the jack point, you may need it someday.
'98 E300, '10 GL350 Bluetec
Welcome to the forum Kevin; pls complete your profile so we know where you are and what you drive.
For the rocker panels you can right here: Sherman Parts - Product List
You want the first 2 items; they are called lower sill, and are $41 each.
Re: Shingleback
Thanks for the link to the lower sills, nice price ! :thumbsup:
Re: Shingleback
You're welcome; just don't buy them out...I still need to buy a pair for myself! :)
thanks!!
I ordered a set today, so when they come in I will weld them in. More in likely i will only replace the rusted section, no need to cut the entire thing out.
1984 190D 2.2
1984 190D 2.2
Anybody? I'd like to do this soon since I am leaving the 201 outside back at home after thanksgiving break
1 - 8 of 8 Posts
