Hello, have a look at this link to a wheel & tyre fitting chart, might give you some pointers, regards Damian.Does anyone know if 19" wheels with 285/35/zr19 tires on the front and 285/30/zr19 tires on the back will fit a 2000 slk230 without any modifications
Thanks for any help.
Going to trigger the ESP light since to rolling circumference is more on the front than the rear (front wheels turn slower, so ESP computer thinks rear wheels are spinning) . Basic rule of thumb: if the width is the same (285), then use same profile (35). If the width is more (say 295), then use lower profile, e.g. 30.Does anyone know if 19" wheels with 285/35/zr19 tires on the front and 285/30/zr19 tires on the back will fit a 2000 slk230 without any modifications
I have tried an slk230 with 18" wheel, the starting was terrible. Why 19" ?Does anyone know if 19" wheels with 285/35/zr19 tires on the front and 285/30/zr19 tires on the back will fit a 2000 slk230 without any modifications
I got 265 on the rear with 19". Fenders were rolled to install them by the previous owner.Saw some foose whells with tires for sale real cheap. Decided against it though after going to one of the response links.. thanks for the responses
