'99 E55
I just added custom valved Bilstein's with H&R springs to my E55. I now want to change my tire size from the stock 18's to 19's - if possible, I would like to go to 10" in the rear instead of the 9.5"
Can I fit 19x10 in the rear without rubbing? I've heard it's possible, but I don't know where to find the right tire size and wheel offset.
For the front, I'll keep the width (8.5) the same.
I'm planning on Carlsson 2/6 or Brabus Monoblock VI
Any help would be appreciated.
BenzWorld Tire & Wheel God
a 19x10 with a 35mm offset has been known to work on most w210 E55's but, since the fend...
a 19x10 with a 35mm offset has been known to work on most w210 E55's but, since the fenders are rolled by AMG and it is a hand done job all of the cars do vary a little so, you may need to massage the rear fenders abit
'99 E55
Tire Size
Thanks Luke - I forgot to ask...what tire size should I go for since I'm going to 19's - want to keep the same outside diameter.
Can you give me measurements for 19x8.5 (front) and 19x9.5 (rear) and also 19x10 (possible rear).
Thanks a million.
use these tire sizes
245/35-19 Front
275/30-19R rear...
245/35-19 Front
275/30-19R rear
2000 E55, 2002 WRX
RE: 19" Wheels on a 1999 E55 - HELP!
how is the ride quality from stock? are the road imperfections more obvious? is it worth lowering? i still want the car's suspension to react like stock. i got a 2000 e55. just curious i too have just bought some new rims Brabus 19 monoblock's V. Need more input to find a good shock and spring setup. thanks.
2000 E55, 2002 WRX
This is what i want to lower but not sacrifice ride quality.
And this Gap is what i want to fill up. but then again not have to worry about rubbing with 5 people.
so any suggestions would help me out tremendously.
