I was told by my mechanic that if i put on 18' wheels on my car, the speedometer won't read the miliage correctly. It would actually be slower than what the speedometer says, it this true?
If you use the right size tire to match the diameter of the stock tire which is a combination of how wide the tire is and the profile series, it should still be accurate. If you use the wrong size tire, then yes it will throw your speedometer off. If you go to tirerack.com, find a specific brand and model of tire you like, then click on the spec it will show you the diameter of each tire.
Does anyone know if the speedometer sensor on a 2002 (w208) CLK 55 AMG is on the front or rear axle ?
I am thinking of increasing the diameter of the rear wheels, by either increasing the rim size to 18 inches or by increasing the profile. I am concerned that this will affect the speedometer. Will it ?
There are speed sensors on each wheel. As previously posted, just match the overall diameter of the original tires. Any tire shop worth dealing with can do this for you in a matter of minutes. Have you checked out the Tire Rack's fitment page on their website?
on my 560sl the front brakes come on after driving a short distance... Along with that the brake pedal pedal appears to be spongy... I also do not think the brake fluid has been changed in probably 20 some years...
Any advice will be greatly appreciated
Mick
Hello all
I've never owned such a fancy car. Can I use a floor Jack and stands and rotate my tires at home? I was wondering if I somehow need to tell the computer that the wheels are now on a different spot. Someone mentioned a diagnostic tool was needed to be plugged in to the On Board...
In my 2012 S65 I hit a big pothole and blew out my left front sidewall (sounded like an explosion from inside the car). I replaced the tire, and a couple thousand miles later I noticed significant wear on the inside edges of both front tires. I took it in to the dealer for an alignment and the...
I bought an A-class automatic 10 months ago. Since then I have driven 22K km of which I’d say 85% of this was straight motorway and minimal breaking.
I’ve just brought my car in for a service to the garage I bought it from and they told me that after 10 months, my brakes are worn to 90% with...
Hi all,
After replacing rear airbag suspension for my E350 Wagon 2007, I'm still seeing a malfunction message on the cluster with the arrow under the car. My mechanic assures me that all is in order. Does anyone know how i can delete this message?
