C36 C43
Hi
I have a 1995 C36 AMG. I want to put 18s on it but i also want a pretty low drop. What size and brand should i get also i need ones that are pretty cheap but good quality
BenzWorld Tire & Wheel God
truncated from your other post
I was wondering what i should do to get a new low stance for my C36. I want to run 18inch monoblocks or something like that. What tire size should i get. I also want a pretty low drop. Will H&R sport springs be enough??
Regardz,
J Nolte
"A Benz is a Benz, BMW is just another car"
18's will work fine even after the car is lowered use an 18x8 front with a 225/40-18 tir...
18's will work fine even after the car is lowered use an 18x8 front with a 225/40-18 tire size and an 18x9 rear with a 255/35-18
H&R's will give you approx. 1.4" drop and by changing the spring pads you can attain another .5" so that would get you almost 2" lower ....
wheel search
http://www.tirerack.com/a.jsp?a=CQ4&url=/wheels/index.jsp
tire search
http://www.tirerack.com/a.jsp?a=CQ4&url=/tires/index.jsp
Suspension Search
http://www.tirerack.com/a.jsp?a=CQ4&url=/suspension/index.jsp
C36 C43
Re: 18's will work fine even after the car is lowered use an 18x8 front with a 225/40-18 tir..
wheel search
tire search
Suspension Search
HEY Luke thanks but i have a few more questions. What are spring pads? Where can i get them? And how much are they? Also how much are the tires?
