2000 E320
sup guys...got a set of amg wheels et31 and et35 with rubber offered for 2100 canadian. is it worth it? if not how much should i offer? these are the specs of those rims
225/40/18 Front ET 31
255/35/18 Rear ET 35
thanks guys
2000 E320
haha...sorry but i didnt understand anything u said bout the specs... i m like a beginner know nothing bout rims or specs...can u like make it easier for me to understand...thanx
CLK320
The following is the description of the tires on the rims you are interested in, 225(width)/40(height)/18(rim size) for the front with an ET(offset) of 31 and 255(width)/35(height)/18(rim size) for the rear with an ET(offset) 35. Storm's suggestion is basically indicating that you go with a wider tire all around. 10mm larger on the front and 10mm larger on the rear, the rest is the same as you first mentioned.
A lot of info on tires (tyres) can be found on www.tirerack.com
