1985 500SEC
i just got a whole history of all the work done on my car since i purchased it, 17 months ago... so, might as well
here's what work/maintenance one might expect during the 2 subsequent years of purchasing a $2-4k 190, as it was in my case
Work:
Muffler
Balljoints
Front stabilizer bushings
Front wheel bearings
Engine mounts
Rear shocks
Rear shock topplates
Front shocks
Front shocks topplates
Breather hoses...many
Valve cover gasket
Headgasket
Oil filler cap
Front bads
Front discs
Rear pads
Rear discs
Rubber jacking point supports
Brake pad sensors
Swaybar bushing kit
Front hood shocks
Thermostate
Engine temperature sensor
Thermostate seal
Bilstein shocks
Auxiliary fan switch
Idle control valve
Thermo Vacuum valve
Alternator
Resonator
Maintenance:
Antifreeze flush
Distributor cap
Distributor rotor
Brake fluid
Spark plugs
Antiseize, lubricants
Fuel injection clean/motorvac
Antibrut
Engine flush
Differential oil flush (85W-90)
Transmission fluid
190E 2.6 5spd
I don't think everyone keeps their 190 so clean though :p
In 2 years, I spent on a rad, water pump and GR2s with H&R springs, engine mounts and 2 sets of discs and brake pads (they rusted out) oh, and a hood lock.
Mine isn't in the greatest of shapes though but yeah.
With all the work you've put in yours, it shouldn't have any problem for a while now. No?
1985 500SEC
hehe 190's look too good to let them get dirty :D
But yeah mechanically all i have left is to change the gear selector seals and the car will be in tip top shape.
What will follow is bodyshop work. I've just recently noticed some rust forming behind the cladding on my driver door :crybaby2: so that will need to be fixed ASAP, and i'm guessing while i do that i might as well remove all the cladding and grind of any other rust spots that may be invisible right now.
..fresh coat of paint (199 Blue-Black), new schatz grill frame with OEM inserts painted black and that will be it for this car!
Once these last items are done... i've always wanted a 560SEC :D
It would be a nice change from my 109bhp 1.8 litre hehe.
