Hi W_M,
I am more than a little familiar with this phenomenon of intermittent dead battery. I installed a 200A current shunt and together with the 6 digit HP DVM could read down to milliamps (as it appears you are able to do as well).
My conclusion is that it is the headlights. I started looking at the air suspension pump behind the right front bumper area under the headlight. On my car (2017 gls63), any key or door-relates action causes the internal headlight motors to start running. Usually they time out after a few minutes, but sometimes they keep running. The bit of info I have been able to collect says that the pointing motor(s) are "homing" themselves. Both lights do it together, put your ear to them. Draw is 4A or thereabouts. Is there some gear or clutch slipping and the home sensor (optical, magnetic, current draw at end of travel? i dont know.) isn’t tripping?
I ran into something about a slipping gear somewhere iirc. At 2-3K/headlight it is hard to think about replacing them on a lark. Next time I am at the dealer (almost never) I will ask them to check them for a software update.
I thought I had a fuse ID-ed that I could pull, but nothing under the hood seemed to stop the motors. I have pulled the neg bat terminal once or twice to stop them from running on. I have the electrical diagrams so I should check there for a fuse to pull.
I have also purchased a RF headlight assy with a cracked case on ebay to a) practice pulling the lens cover off without destroying it for access, and b) to take a look at the motor & mechanisms and see what is up in there.
I also purchased a 12V/50A power supply and outfitted it with 2 jumper cable clips and a long extension cord. This lives in the tire well. (for emergency charging) (its voltage adjustment pegs out at 14.5 or so, so I might get the 15V version next time)
This is an extremely annoying problem, bordering on dangerous. I can't believe there isn’t more chatter about this issue. Maybe people are changing headlights out? Or indeed there is a software fix out there? Why doesn’t this show up in a service bulletin?
Anyway, take a listen to your headlamps afterstopping/locking the car. They may be tripped by key proximity, too, so I have a ritual to always lock the car and keep the key out of range when done driving. Along with jumping up and down on one foot while rubbing my belly and chewimg gum; something I learned while getting my BSEE....
looking forward to hearing about what you find!
-Hugh
So this vehicle has occasional habit of killing battery dead overnight. It happened twice before. Battery replaced in mid December. It was 5 years old and failed capacity test
@350 CCA.
On January 15th it died overnight. It arrived on tow truck with battery voltage at 2.72V. It took 12 hours to get it back to normal at 10A charging rate.
Checked quiescent current. It starts at ~25A, after 30 minutes or so goes down to 0.007A. That is very low. I am used to 30-50mA on most modern MB cars.
I cannot find in WIS normal quiescent consumption or prerequisites to testing.
Maybe
@konigstiger can help?
VIN 4JGDF7DE5HA745391
Attached scan after battery recharge. Obviously low voltage faults galore.
@350 CCA.
Maybe
(not sure my reply made it thru as such. copied here. -Hugh)
Hi W_M,
-Hugh
