1993 500E, 1983 500SL
Does anyone know if the 16" ML320 wheels fit/clear the brakes on my ML55. I was thinking on getting a set with winter tires.
Thanks for any advice you can lend me.
Tom
1999 S600 Sedan, 1999 S600 w/ 4-pl seating, 1995 S600 Coupe, 2-1992 600SEL's, 2002 ML55, 1998 SL600
Tom, stick with the dimensions suggested for the ML55 - 18-inchers. You've got uprated brakes, and even if the wheels fit, there may not be enough heat dissapation with the smaller wheels.
Why choose cheese-y solutions for your supercar?? Go with the second set of wheels with the snows, but have them fit. They're available from the shmucks out there fitting on 22-inch wheels. ML55 wheels not only are larger, but wider, too.
2007 ML 500, 2008 ML 550, 2011 ML 63 AMG
Be careful with the width though, the whole point of winter tires is traction.
The wider the tire, the less traction you will have. The bigger tires will tend to ride up on top of the snow, instead of biting through it.
In my case I put 235/65R-17 Michelin X-Ice tires on my ML500 and the difference between it and my buddy's identical truck with 275/55/17 Goodyear Fortera tires on it is night and day.
