my locks won't lock I have to do it manually. this includes all doors, the trunk , even the switch in side the car which locks and unlocks everything. I checked fuse #5 under the hood working fine. checked fuses #3 & 11 in the trunk working fine also. I was told it may be a pump (pse)....where would i find this pump at in my car and is there instructions on how to replace this....No alarm is set to this which i hear will make the switch easier...and oh yeah how much does one of these pumps run for
92 500SEL to 01 E320T current 2014 lexus LS460
The locking pump is under the rear passenger seat in a foam container, with hoses coming from it. There are two versions, the latter does not have the plenum and you need to get adapters like "t"s and plugs for the various lines, they are available in the $300s but more from the dealer
W140 Moderator
"CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
Hi
Have you checkt your Remote Batteries,it cant just happen all in one hit without any Symptom's 1st ,any airhissing noises or anything ?
Ciao
1996 S320
Try this....
Desconect your battery main battery and wait for about 15 min and then reconnect and try it. It worked for me.:)
P.S. Before you do that, if you have original stereo make sure that you have code that unlocks your stereo.
