1981 U1300L
help!
here is the situation............ i have power at the fan switch,and the 3 wires that come out of the switch have power. these 3 wires go inside the heater unit and i havent been able to trace them down circut from there. but there is no power at the blower motor....any ideas?
id be most grateful for any help.
cheers, kris
SBU
You most likely have a bad motor. I have had lots of them do it. Your best bet is to pull the whole heater box out, take the heater core to a radiator shop and have it checked and rebuilt, take the motor and switches to a auto electric shop, it is usally a bosch motor, easy to rebuild or replace, take the heater box case, blast it and repaint it, put it all back together and you have a new heater box for about $100 VS. $1400 from MB.[:D]
SBU
Your "3" wires should be 1- switched power from ign switch, 2- ground wire, 3- should be a wire to the condenser/relay. There should be only the 1-2 wires coming from the truck to the heater, then inside the heater is the 3rd wire. hope this helps.[:D]
