I'm in the middle of installing my Mobridge Ipod integration kit into my USA spec 2006 SL65 AMG and I have everything wired correctly except I need to tap into a 12V power source. I was wondering if the CD changer that I removed was running on 12V power and which wire I should tap into.
This is the connector that I removed from the CD changer, could I tap into any of these for a 12V and a ground?
Here are the 12V wires from the Mobridge I am referring to.
RHD C200K Sport Coupe, RHD SLK-55, LHD SLK-350
Absolutely - the blue is un-needed, unless you need MOST wakeup for the mobridge. The brown wire is ground, and the brown/red is +12vdc.
If you want the part numbers for the connector and pins that plug into the CD harness, drop me a PM. If you don't care about it, just cut the connector off.. ;P
