1 - 9 of 9 Posts
2005 E320
What is the difference between the 12v socket at the rear and the cigarette lighter at the front? I understand that one can plug a cooler box for instance, into the 12v socket. Can I however, plug my portable GPS' charger into the 12v socket at the back, or MUST I use the cigarette lighter's socket?
Thanks so long.
2004 E320
1985 300CD Turbo coupe, 2006 E320 CDI sedan
Mine is marked "do not exceed 150 watts". So I plug a 150w inverter into the trunk receptacle. That way I have DC power from the cigar lighter receptacle, and AC power in the trunk
//greg//
AFAIK, diesel w211 12v outlet are all 15A. no idea on the gasser version.
Can't see where the engine has anything to do with electrical distribution. Diesel, petrol, it's still a 12v system. But if you saw 15A somewhere, I'm thinkin' that must be a surge rating. Cuz mine's clearly labeled as a 150w outlet (that's a nominal 12.5 amps DC).
//greg//
Mine said "Max 15A" on the rear socket. Going by the 85% rule, it is about 12.75A.
Is this "85% rule" a Canadian thing? Cuz I'm a retired EE tech who still goes by Ohm's Law. But even accepting this 85% rule, your "15A Max" label, almost certainly indicates the surge limit. As I said, mine is labeled "150 watts". Given a 12 volt supply, Ohm's Law still makes that nominal 12.5 amp outlet.
I don't really see any need to bicker over a quarter amp. I'm only clarifying so folks don't read this - and arbitrarily plug in anything that says 15A on the label. I'm still considering it a "15Amp surge" rating.
//greg//
2005 CLK320, 2009 E350
Any issues with tapping off the rear adaptor for 12v to power a small backup camera?
My biggest thing I want to know is does the outlet shut off after the ignition is off? I don't think I'd want the camera on ALL the time even though it only uses up 70mA... which isn't a lot but I'd just prefer it to be off when the car is off.
Thanks,
-Nigel
1 - 9 of 9 Posts
