RE: 129sl interior /exterior upgrades
Hello all! Happy New Year. Just an update on a topic I bought up last year. I asked if anyone had done a door panel upgrade from 90-95 to a 96 & later panel, no replies. I have successfully converted to the later style panel, boy what a difference it makes.
Now I will tell you this conversion is not for the skimish!! It has taken some time and thought. First off the panels are VERY EXPENSIVE!!!!!! about 1,100.00
at the dismantler. OUCH!!! But I had to try!! You must modify the speaker housing(trimming about 2" off), relocate the bracket to mount near the door handle, on the new model there is one screw plus the plastic clips. Now if you are sitting down, the biggest chore is that you have to put in the door knob (early car do not have) so to keep the door actuator working I had to buy the parts from the dealer( approx 30.00) clips included. there is a plastic housing that has to be cut to add in the door knob hardware, I simply used small yellow ties to secure to the stock location, it works. I will have to take some cutting to the top of the rail to allow the decorative door knob trim to sit flush with the top of the door panel. It's a lot of work and I still need to do the passenger side.
I will have all the kinks worked out, so it should go much smoother. I will keep you posted, and will try to post some pics this week. Keep in mind that you will have to dye match after installation is complete.
Leave this to a professional. I also won some late style mirrors on ebay (oval shaped) they are mounted, but I will need to make up a wiring harness since there is only one plug-in instead of two, I think I will wait until spring to tackle that one. If there is a benz electrical guy reading this I will accept ANY HELP in trying to figure out the harness thing.
I must say that I love the look of the conversions, but it does take some time and much thinking.
Will post pics soon
rundlc
