I'd put something soild under the rear axle, lots of lever arm on the shock mounts and panhard rod if something slips and the whole torque tube drops. Getting the LH shock top shock bolts out is a bit of a mission if you don't tilt the cab on a U1250, but can be done, just did mine by cutting the bolt off and replacing it.
What the shims on the torque tube, so you don't lose any or mix them up, getting the right shims correct when refitting the torque tube requires a special tool from MB. Not sure if you have the U1250 workshop manual, let me know if you want the Transmission part.
