1 - 1 of 1 Posts
1963 404.113 1957 411.111 Frogeye
There several disparate threads on the 123 Ignition; I have a couple of questions so I will link those here
My original distributor's advance place seized up, so I bought a 123 Ignition distributor You will need a 24v -> 12v converter; they have one on their site for $40, but I got the exact same one on Amazon for $20.
First question: which curve setting are you guys using with an otherwise stock engine? I found this thread which suggests either 0 or 2. However, their technical chart shows curve 1 being the same as 0, but for low-compression engines. (see charts below). I currently have it on 0, and advanced the timing at idle to where it seemed to idle well, but now I'm getting pinging at high RPMs, so I am going to dial it back a bit.
Motor vehicle Automotive air manifold Automotive exterior Automotive fuel system Auto part
This thing has the smoothest idle ever
Font Material property Number Monochrome Document
Font Number Pattern Parallel Monochrome
1 - 1 of 1 Posts
