Hello,
I currently own a 1985 300d turbo which I rather enjoy, but recently saw an add in the paper for a 1979 mecercedes 300sd w/160k miles for only 1500 dollars. I know that a 123 with that mileage would be much more expensive. I wanted to know if anyone out there knew the differences between the two models/reliablity was the S model a higher quality?
Are the 123's more expensive b/c they are more well known?
Will most diesel engine cars go 300,000 plus miles because the diesel engines are built to handle much higher compression (ie VW's or other mercedes diesels) Or is it the design of the 123 that is unique in this regard--I always figured it was not.
Finally, is this car for 1500 dollars a steal or not
thanks
thanks
