Has anyone come across a vibration when you rev engine to 3000rpm seems to come throagh exhaust, feel it while driving at 3000rpm and free reving. Engine mounts are fine.
Its not uncommon for vehilces to do this, particularly commercials where less time is spent on reducing NVH (noise, vibration and harshness). My 115 has some resonance under load at higher rpm but not standing still.
Since you can get yours to do it standing still, we can rule out driveline components.
Next culprit will most likely be a piece of exhaust system coming into contact with the body somewhere. The exhaust should hand entirely from rubber mounts and the only place its rigid if onto the engine which itslef has rubber mounts to help damp out vibes. Suggest sliding under the van (well chocked etc) and getting one of Walsi's assistants to rev it up while you investigate (the van that is, not the other Walsi assistant!)
Also check for any heat deflection plates if fitted.
Cheers
Vito 110CDI 03, Fazer 1000,
Or you could just slide under 1 of Walsi's assistants (avatar) let the vibration begin
108d big orange shaggin wagon v280 639 109
y not get both of walsi assistants to help and im sure u will find a vibration between them :thumbsup:
