1 - 1 of 1 Posts
vito 108 cdi 1999
the story so far,brought van 2 years ago 108 cdi 1999 it had not been looked after ,have done black death thanks to all info on here,van was running fine then two weeks ago cut out suddenly,finaly got it to start drove back home checked it over to find air in the fuel line,replaced filter,fuel line from filter to lift pump primed the system and got van started.
ran fine for a week then would not start and had to be towed back. cheked fuel lines and found bracket had snapped allowing fuel pipe to touch belts,replaced line
have replaced fuel filter ,filter to lift pump,high pressure pump to rail all with gen merc plus new o rings on remaining line ,
now van will start and run for about 15 mins and then cut out,leave overnight and again starts first time runs for 15 min then cuts out,
no fault or warning lights on the dash HELP:surrender:
1 - 1 of 1 Posts
