I am approaching the 100K mile milestone on my ML 430 and I know it need a major service. I wanted to find out what should I have done. Do I need to do everything that it is stated in the manual or are there things that I should not worry about.
The sparkplug I am doing for sure but don't know about anything else I should be doing.
Thanks,
Change your vehicle's engine oil and filter
Replace the dust filter in models without the active charcoal filter
Replace windshield wiper inserts
Inspect and rotate tires
Lubricate and inspect throttle linkage
Inspect tires and check tire pressure (including spare)
Inspect brake pad thickness and disc condition
Inspect front axle ball joints and Poly-V-belt
Check and correct all fluid levels
Reset your vehicle's FSS counter
