Recently they started selling gas with 10% Ethanol mixed in Florida. Is it a problem? What % is a problem? I heard that ethanol kills engines. Some say it wont hurt, it is even better! Can W210 engines tolerate this mixture? (too many questions!
I wonder if the opposite also applies, that is a you take a CA car outside the state and fills up with non-ethanol fuel, if it could also trip the CEL until the computer re-adapts?can handle 10% however it is oxygenated fuel and some cars with mass air sensors on the verge of a certain value in voltage will relay an out of range data set and may trip a check engine light.
ohlord:bowdown:
Thanks - I like it when a mystery is solved.and yes.Same with driving to states that have high octane premium like 94,can trip a light.Even altitude changes
ohlord:bowdown:
Water in the fuel is always bad, but it is much more tolerable if it is absorbed by the alcohol. When I lived in the frozen north, we routinely had to add alcohol to absorb water. Otherwise it can freeze in the lines and prevent you from going anywhere.some interesting posts in here.
1. Matt, why would you think its a good thing that it absorbs water. Thats a pretty bad thing in my book.
