Thanks for the chart, I have some idea that the 1/4 mile speed is going to be high,if you go by the chart and use the 0-60 in say 8sec, a drag strip is 1320ft.
If you figure in a professional driver [me] with track time, blow up the tires to around 45lbs, power brake the trans to stall speed [not recomended] and wide open throttle, shift manually at red line, it should run someplace around 100mph. My guess is around 15sec.Remember no wheel spin! I will make several runs to see, then see which one of the MLs [99 430's] will need the trans rebuilt!
Oh and the ESP "off"
jd
