my heated garage kept, weekend drives only ML developed an usual issue today. The doors have always locked and unlocked fine, never any issues. ML has keyless go, and as long as the key was in my pocket, just touching the handles would unlock the door. Well, today, at my 3rd stop, I had my family with me, they opted to stay in the car while I ran into the store. I left the engine running (MI is still cold this time of year) and went about my business. I returned to the parking lot and the door would not unlock. I tried the door handle, the handle button, the keyfob, tried cycling the locks, nothing. My wife hit the unlock button on the passenger door, nothing. She reached over to hit the unlock on the drivers door, nothing. Finally, she had to pull up on the lock knob. Now, the drivers door will not lock at all, and I cannot even force the lock plunger down, as it has something resisting and is pushing back up. I check all the fuses and did several searches and came up with nothing. Short of taking to the dealer (several hours drive in 1 direction) I am actively seeking a solution. Perhaps someone reading this has had a similar situation and found the fix to be something simple, like lock re-syncing or a menu option needs reset.
Hello,
We have an 09 ML63 here in MI as well. What I've heard is that it could be several things and the only way to really check is to scan it. You can try and disconnect the battery to see if it clears any faults stored in the system and starts working again.
If you are close to Kalamazoo, I can scan it for you. You said you are several hours from a dealer so I'm guessing you are far from me as well. There is a dealer about 5 min from me.
what type of scan ? typical snapon solus or star ? I have a solus available to use, just never give it much thought.
my replacement secondary battery arrived the other day, when I get some free time, I will swap it out and see if anything resolves.
