2008 E350 110k, 2000 E320 143k, 1983 380SEC 240k
Please suggest tire sizes for my car, as I will need to replace them soon. I am cross-posting from the Tire, Wheel, Brake and Suspension forum because I did not receive any responses there.
The factory wheels were previously front: 8.5J X 18 H2 ET 38 with 245/40R18 tires. Rear: 9J X 18 H2 ET 39 with 265/35R18 tires.
I am the second owner. The previous owner replaced the originals with all 8.5J X 18 H2 ET 38 wheels with 235/40R18 tires front and rear. I plan to keep these rims, but possibly use different tires.
My tire knowledge is very limited, but I know that there are limitations to the diameter and width that can be used without causing problems. Also, that handling, ride, etc. will be affected. Despite this being a sport model, sporty handling is less important to me than ride comfort. So please let me have your recommendations. I would also appreciate some info on the tradeoffs if different tires are feasible. TIA.
Undercover Moderator
2002 SL BRABUS 5.8 Silver Arrow; 1992 SL BRABUS B11; 1996 S Class diplomat ride
Yes, you could use factory recommended size 245/40R18 tires with the rims you plan to keep...
Cheers, 馃檪
Cheers, 馃檪
Thanks! I'm not sure how much the extra width and sidewall height will help soften the ride, but I suppose it would be noticeable?
A tire size calculator tells me the circumference of the rears will be 1.6% more than OEM. I assume this is too small to cause problems with the transmission/ABS/whatever electronics of the vehicle?
245/40/18 will ride nicer than your current 235/40/18
You could use 245/40/18 for the rear with no issue.....
Cheers, 馃檪
