A little background. This 08 GL320 has always been slow to crank. Sometime it would crank fine though Sometimes cranking so slow it did not seem like it would start but it would. It has keyless go and it seemed like if you hit the button and it cranked slow, hit it again to cancel and then hit button once more and on the 2nd go it would seem to crank like normal. A while back I had planned on having to replace the starter because the battery is new, cables are all good etc but decided to do a voltage drop test. Its been a while but it seems like all the lines were fine but I was getting too much drop between the battery connection at the battery and the jump post under the hood. No drop between post and cable, or from starter to connection behind alternator, or from there to the jump post.
First question, is there a connection point somewhere between the battery and the jump post? This could be where my drop is.
Now, new problem perhaps related to old problem. Wife was at the store yesterday, went to start it, nothing. No click, no nothing. Key seems to activate everything when turned to position 2 just no cranking. I hooked it up to SDS today and all systems appear to be go as far as drive authorization. Perhaps I was wrong in my previous testing of voltage drop and it was OK and the starter was going bad, and finally kicked the bucket. Its currently sitting in the driveway and I have not been able to do much with it yet beyond the SDS scan. If I do need to replace the starter I have a W116 on the lift I need to try to get finished up tomorrow so I can get this up in the area. I am going to have to get it into the shop anyway to do any major testing on it. Do these have a connection point anywhere that I can connect a remote starter switch to see if the starter cranks? Is there any sort of starter relay, or fuse that might be bad I need to check?
