07 E350
does a 07 e350 have a trans dip stick/ filler tube? ive used the search feature and cant find the answer. if it doesnt does someone have a link to the pump that pumps the trans fluid into the pan? thanks
07 E350
Discussion Starter #2
searched some more and found the answers to my question.
trans has no filler tube, fill fluid and top off will have to be pumped in thru the drain filler plug in trans cover.
mb does have a special tool/pump to fill the transmission. looks expensive but in all reality its just a pump.
conclusion, the trans service is not a dealer service only item.
im going to order all the parts, filter, gasket, 6 pan screws, and shell 134 atf fluid and do it myself. ill have to buy an inexpensive hand pump and some fittings to perform the fluid fill but it really is a piece of cake. something to keep in mind is that when fluid level is checked the temp of fluid needs to be at 35 degree celsius if you have the old style pan or 40 to 45 with the new redesigned one.
