2006 Mercedes Benz E350
My A/C is not cooling. :crybaby2: When I press the A/C button, it blinks a few times and then turns off. In an '06 with 59k miles, is it probably just the freon/refrigerant or could it be something more serious? I haven't had any other problems with the car other than it's due for Service E.
Any input would be appreciated. Thanks!
E350 4M 06
Pull the codes and it should tell you what's wrong, if its low refrigerant then you have to find the leak, the system is very robust, this is not a common problem.
Super Moderator
With a high end scan tool like the Snap-On Solus or the Mercedes SDS system.
