21 - 22 of 22 Posts
1999 E320, 2000 E320, 2003 E320 Wagon, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
You are supposed to drain it from ths pan underneath. Trans fluid is then pumped into the pan with a machine, after you drop the pan, change the filter. This is pretty much how we do a trans service. If you must do it yourself, there is a dipstick tool you need. The cap comes off usually by breaking a tab off, then lifting the cap off. You can fill it with a funnel from the top. Roughly 3.8 qts.
This procedure is for the 722.6 5 speed transmission only, not the 7 speed.
MY05 CLK55 AMG ,CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Only the 5 speed 722.6 can be filled from the top.
The 7 speed can only be filled via the pan drain hole,,by pumping the fluid up as per Rudeney's post.
Sorry 260e ,,I did not see your reply there..
21 - 22 of 22 Posts
