as typical on older benz my fuel sending unit is no where near accurate. also suspecting the pump in general is dying. so i ordered a new assembly and was curious if the filter is built in or is it seperate?
2000 ML55 sold? 2013 ML500,? 2017 C43 AMG,1929 Victory 6 roadster, 1927 Dodge 4 sedan, 1929 Dodge
Filter is a separate unit in between the body and chassis in the rear left hand wheel well. If your changing the pump it’s a great time to do it because you can get at it from both sides. You think callipers are a pain In the ass wait until you do your filter. Lol.
thanks for the info. i run my own mechanic shop, cant be any worse than half the other crap i work on every day lol
2003 ml500, 2004 ml350
You probably have them if not you will need the line pliers. Also on later mls you have to remove both rear seats there is a tab on the 1/3 seat that over laps the 2/3 seat. Something like 14 fasteners holding them down.
And I agree with Matt easier to remove pump then remove the filter. Keeping the two pump lines still attached to the filter, install in reverse.
