George, check the hinges on the cover. There is a locking mechanism made of plastic that helps support the cover in the full-open position even if hydraulic pressure is lost (it's a safety feature for when working in the compartment with the cover open). Sometime the plastic arm breaks and can make it difficult for the cover to close, and may even make a loud "pop" noise as it closes (to chrisos1's comments). If the plastic arm is broken, you can just go ahead and break it off completely to remove it - again, it's just a safety when servicing with the cover open. If it's not that, then I think you have a bad hydraulic cylinder.
