2005 CLK55 AMG Coupe ,CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
I would suggest first of all , fix any oil leaks up top , such as valve cover gaskets and breather cover sealing.
Also check the oil cooler and oil filter housing for leaks at the front of the engine and also the dipstick tube gasket.
Then clean off the underside , and check it again after a couple of days to see if and where any oil is coming from.
Rear main seal is something you only want to do if it is really bad , and all other leaks have been eliminated.
Rear main seals quite often leak on these engines , but in many cases are not bad enough to justify the expense of fixing.
